150 4 stroke mercury - Im stymied!!
RST
I have a 2013 150 merc 4 stroke. Last year after trying to get it over 4000 RPM it would just die off till I throttled back. Runs fine up to that RPM. I change water/fuel separator and low pressure fuel filter - no help. So - get a tune-up last month (mercury mechanic) and tell mechanic; he calls saying it was only a bad plug ( sure seemed like fuel problem to me). Go out and all fine up to 5000 RPM for 30 minutes - then it sputters and dies back till I throttle back under 4000 RPM again. HELP!!!! Not sure where to go from here
Thanks for any tips!!
Chris1956
Honorary Supreme Mariner
Clearly you need to make sure your fuel system doesn't have a restriction. Check antisiphon valve. See if A-S valve has its own filter. Some do. You can remove it for test.
FTR- I think your mechanic was fibbing.
If you have an on board tank , then test run with a portable tank and hose.------
