Oregonbythesea
Thread starter- Joined
- May 28, 2009
- 14
This board has been a life saver for me and I want to thank all those that respond with information. Without the help here, my boating activities would have to be put on hold.
My latest problem concerns a 15 hp 2 cycle Merc. It is a newer one (about 2000) with less than 15 hours on it. I replaced the plugs and gapped them at .060. I removed the carb, soaked it over night in a carb cleaner. I then used the air compressor and tip cleaners to make sure all the ports were open. Cleaned the filter and filled the tank with new 50:1 gas/oil mix. I got it started and it ran for about two minutes and then just shut down. I can't get it started even by choking it. I disconnected the kill switch and fuel sensor (?) wires to make sure it wasn't a ground from them. Any ideas of where to look next would be great.
