15 HP powerhead gasket replacement
Rifflerunner17
My new gasket appears to be "stickey", does it require gasket sealer? If so, what type, brand do you suggest when replacing the powerhead.
Thanks, Riffleunner
fireman57
Re: 15 HP powerhead gasket replacement
I personally do not use sealer on them. Just make sure that the surfaces are totally clean and the bolts are torqued to the proper pressure. After you run it for a few hours check and retighten them to the proper torque. Check your manual for the tightening sequence and foot pounds of pressure. You will want to buy or borrow a torque wrench.
F_R
Honorary Supreme Mariner
Could you be referring to the cylinder head gasket? They come pre-coated with sealant and nothing else should be added. I haven't seen other gaskets pre-coated, but that doesn't mean they aren't. Too new for me.
