15 HP Evinrude - Idle Problems, Trying to avoid motor rebuild
Abelinkkin
Hello Everyone,
I have a 1994 15 HP Evinrude E15RER. I am going to be using this motor for my duck hunting boat so having it at 100% is a must. Don't want to be stuck in the middle of the lake at 3 in the morning during winter.
So far my list of repairs are:
Compression check - 70 psi in both cylinders
Rebuild and clean carburetor
Adjust carburetor cam/roller
Rebuild fuel pump
replace spark plugs
replace fuel hoses starting at the engine. (have not tried a new tank or primer bulb)
The manual says to set the throttle about half way when cranking. It will usually start after 3-4 pulls. But when you turn the throttle down to the "shift" position it dies. I messed with the idle speed adjustment screw all night last night and couldn't seem to get it dialed in.
Leaving the throttle about 1/2 way (to keep it from dying) the idle would fluctuate up and down like it was leaning out and then fixing itself.
The compression numbers seem low by some peoples standards but a friend of mine that works on motors all the time says these numbers are fine so I am not sure what to think. Would those compression numbers be low enough to cause the motor to not idle at low speed? I really would like to avoid taking the motor apart and replacing the rings so any other advice is appreciated.
flyingscott
I would recheck the carb work. Is the low speed needle adjusted correctly? And did you clean all the small passages and adjust the float correctly.
Abelinkkin
Pretty sure everything is adjusted correctly. This was the second rebuild I did on the carb. Once right after i bought it and again during this round of repairs. Float was adjusted correctly and blew out all the passages with compressed air.
One thing I have not done is a decarb. How much white smoke is too much for a 2 stroke motor like this?
flyingscott
Has this motor ever been overheated? Do the sparkplugs look clean and shiny. I would also say re-check the compression with a different gauge that is a little on the low side. But since they are the same i would say your gauge is suspect.
kofkorn
70 PSI is low. If your gauge is accurate, this motor will always be tough to start and likely to have a difficult time idling. Older motors would be ok with that compression, but typical compression on this motor is around 125-130 psi. Anything below 100 is on the low side, usually at 60 psi you can't get the motor running. I think that you're already looking at a rebuild. I suggest you look into a good powerhead for that motor and swap it out. I've seen them for around $300 for one with good compression.
Good luck!
Roberthill
I know you are having trouble with idle but for my 2 cents I would recheck carb esp high speed orfice .
raczekp1
i would do rebuilt job. at least you should drop head of and look inside cylinders
bspeth
I think you might be in need of a low speed adjustment,you need to give it time ,like ten seconds in between 1/8 turn adjustments. Your compression gage could very well be inaccurate.
scout-j-m
What is the current low speed needle setting at? In my experience, the plastic topped carb motors like to be richer than the older ones. My early 80's models idle best at about 1 & 1/4 turns out while my 92 model does best at closer to 2 turns out or more. My manual for the 92 model says the intitial setting is either 2 & 1/2 or 2 & 1/4 out from lightly seated.
OMCfan
Your compression seems way to low to me. I would say they should be 100 psi minimum on that motor.
scout-j-m
I'd also try a different tester. I bought a motor from a guy and gave him my cheapo Harbor Freight one that worked great. I replaced it with the same Harbor Freight one which worked fine at first but now only reads 60 psi on motors I know are 110+ psi.
Abelinkkin
Right now it is set at 1 turn out. Any more and it dies at low throttle
Honorary Supreme Mariner
The compression is an issue.---Did the motor overheat ?----Myself I would remove exhaust cover to inspect pistons / rings.
thatone123
Banned
I've had these motors that ran fine with 90's level compression. These motors will run when logic and reason dictates they should not run. I've always wondered if this era OMC outboards under 20 hp were designed by a genius or it was just a continuation of the former years and part luck.
