Abelinkkin
Thread starter- Joined
- Jun 24, 2016
- 4
Hello Everyone,
I have a 1994 15 HP Evinrude E15RER. I am going to be using this motor for my duck hunting boat so having it at 100% is a must. Don't want to be stuck in the middle of the lake at 3 in the morning during winter.
So far my list of repairs are:
Compression check - 70 psi in both cylinders
Rebuild and clean carburetor
Adjust carburetor cam/roller
Rebuild fuel pump
replace spark plugs
replace fuel hoses starting at the engine. (have not tried a new tank or primer bulb)
The manual says to set the throttle about half way when cranking. It will usually start after 3-4 pulls. But when you turn the throttle down to the "shift" position it dies. I messed with the idle speed adjustment screw all night last night and couldn't seem to get it dialed in.
Leaving the throttle about 1/2 way (to keep it from dying) the idle would fluctuate up and down like it was leaning out and then fixing itself.
The compression numbers seem low by some peoples standards but a friend of mine that works on motors all the time says these numbers are fine so I am not sure what to think. Would those compression numbers be low enough to cause the motor to not idle at low speed? I really would like to avoid taking the motor apart and replacing the rings so any other advice is appreciated.
Rebuild fuel pump
replace spark plugs
