15 hp Evinrude has no low speed...it quits!
marcfox1
I have a 15 horsepower Evinrude outboard that is about 10 years old. I have owned it since new and it has only had about 35 gallons of fuel run through it over the years. I only use it once a year, if that. I had it in storage the last two years and I just put it on the boat and it has a problem. There is no low speed to it, it will die if you don't give it a little choke and keep the rpm's up. You can open the choke as long as you have it revving. Wide open throttle is just fine, lots of power. I figured the carb was maybe plugged up so I removed it and took it apart. Sprayed carb cleaner through it and blew it out with compressed air. There was no gum or dirt visible. I removed the fuel pump and fuel filter and all is well there also. Checked the spark plugs and they look fine. I can only think of two things that may give me this trouble. One is the carb low speed circuit tube is plugged. It is not removable and I can't get in there. The other is maybe a crank shaft seal is bad and leaking air. Looking for any ideas on what to do next? I am using brand new fuel and I ran it at wide open throttle for a good half hour.
Fouled Plug
Ensign
Re: 15 hp Evinrude has no low speed...it quits!
I would get a bucket of carb cleaner from your local auto parts place and soak that thing. Then blow out with compressed air, and try again. The soak really finds and dissolves crud much better than aerosols. Just follow the directions, and hopefully it will solve your problem. In the future, fuel stabilizer would be a great idea for such an infrequently used machine.
