morningtide
- Feb 7, 2011
- 10
After replacing the flywheel, I've found that the engine runs well but I've lost neutral and reverse. I speculate that blocking the prop while torquing the flywheel nut, has caused some damage in the bottom end. The bottom end is stuck in forward, while the tiller handle through to the lower end shift rod travel through the FNR positions ok. Problem with the shift cam / cam follower / spring perhaps?
Does anyone know how to remove the prop shaft without having the special tool which manuals refer to?
