15 h.p. Johnson 2 stroke seized?
oldboat1
should be a spring washer and a retaining ring in there -- not sure you have the whole assembly (kind of a simple purpose for all it's parts -- seems like a Rube Goldberg design IMO. Plastic idle screw physically holds the throttle in position, controlled by that knob.) Did you find a reason for things locking up?
probably a youTube out there somewhere on idle control operation (maybe try a google or two). Might look for an '80 service manual on eBay (use parts blowups from evinrude.com or similar.) Maybe something in the way of a manual on iBoats or Ken Cook's website.
edit. sorry, you are moving to the idle speed screw. Different animal -- knob is inserted over the l.s. needle, held in place by friction. Initial setting is about 1 1/2 turns open (counterclockwise) from lightly seated. Can carefully slide knob in and out when working around the stop. Once you have it "dialed in", no need to adjust it more than maybe 1/3 turn or so. I find I have to set mine a little richer (counterclockwise) for cold starting, then set it back (leaner) for operating when engine is warmed up.
OptsyEagle
Once you have it on the slow speed needle turn it out (counter-clockwise) 1.5 turns from lightly seated.
Fire up the motor and let it warm up in neutral. Then reduce the idle to as slow as possible. Turn the knob clockwise 1/8 of a turn and give the motor 5 to10 seconds to respond. If the idle RPMs increase, reduce them again. Turn the knob in another 1/8 of a turn. Continue doing this until the motor coughs and burps and sounds like it is going to stall ... or does stall. Turn the knob back out (counterclockwise) 1/4 turn and leave it. Position the knob so that the pointer is directly pointing down half way between rich and lean and you should never need to adjust it again.
FisheyeFool
oldboat1;n10041086 Did you find a reason for things locking up? [/QUOTE said:
The safety mechanism preventing the motor from starting at full throttle was why I couldn't pull it over.
oldboat1
yeah, been there with any number of screws, bolts, springs, washers.... Long tweezers, those little magnets on extendable arms -- now and then have used the little magnets to start some screws or bolts in tight quarters. Powerful little buggers.
oldboat1
there you go. Let the kid off the hook.
Is the mechanism in place and working? The spring for the plastic lever uses the metal tang on the starter base (rests on the outside of that vertical post for tension). Easier to do than to say. Keeps the lever from engaging when it shouldn't.
edit....but sounds like it worked as it is supposed to.
