oldboat1
- Apr 3, 2002
- 9,612
should be a spring washer and a retaining ring in there -- not sure you have the whole assembly (kind of a simple purpose for all it's parts -- seems like a Rube Goldberg design IMO. Plastic idle screw physically holds the throttle in position, controlled by that knob.) Did you find a reason for things locking up?
probably a youTube out there somewhere on idle control operation (maybe try a google or two). Might look for an '80 service manual on eBay (use parts blowups from evinrude.com or similar.) Maybe something in the way of a manual on iBoats or Ken Cook's website.
edit. sorry, you are moving to the idle speed screw. Different animal -- knob is inserted over the l.s. needle, held in place by friction. Initial setting is about 1 1/2 turns open (counterclockwise) from lightly seated. Can carefully slide knob in and out when working around the stop. Once you have it "dialed in", no need to adjust it more than maybe 1/3 turn or so. I find I have to set mine a little richer (counterclockwise) for cold starting, then set it back (leaner) for operating when engine is warmed up.
