15 h.p. Johnson 2 stroke seized?
FisheyeFool
My kid ran my outboard out of gas and now I can't even pull the motor over let alone start it. Any ideas that might help me free it up would be greatly appreciated!
OptsyEagle
Running it out of gas should not seize up a motor. Can you turn the motor by hand by turning the flywheel, when motor is in neutral and/or in gear? Does the propeller turn? Also, you should let us know what model year your motor is.
FisheyeFool
The motor is a 1980. I haven't even had a chance to look at the motor yet because it happened just as we were leaving camp. I tried to restart motor and could not pull it over. Loaded it on the trailer and came home.
If he was running the motor with the lean/rich dial all the way over on lean would that seize it up?
AlTn
shouldn't have as that just affects the idle mixture...up and running the fuel mix is being forced from the bowl into the carb throat and the idle circuits are no longer in play...did you check to see that the gear shift is in neutral?
FisheyeFool
Yes the gear shift is in neutral but it was very hard to shift from forward to neutral or reverse.
OptsyEagle
Was there oil in the gas. Perhaps it died when it seized and your son thought it ran out of gas. Anyway, try to turn the flywheel by hand clockwise and see if the propeller turns. It can sometimes be hard to shift gears when the motor is not running, so that is normal.
FisheyeFool
Definitely oil in the gas. Since the motor is from 1980 could it be an impeller problem? I will try turning the flywheel when I get home from work. Thanks for your help!
OptsyEagle
Well if it is seized, it could be from lack of oil or lack of cooling water, allowing the motor to overheat. If I were you I would first confirm that it is seized and then look into why, at that point. But yes, if it is seized, I would definitely be looking into whether she overheated and if so, if the impeller or other cooling parts are operational. If it overheated, before I even looked at the impeller I would start taking compression readings and if bad, removing the cylinder head and looking at the cylinder walls and pistons. No sense wasting time on the cooling system if the motor is shot, you know what I mean.
Let us know if it is definitely a seized motor and we can guide you from there.
FisheyeFool
Ok I can turn the flywheel by hand and the prop turns when in forward gear.
Pull cord won't budge. So I'm assuming the motor isn't seized.
oldboat1
With the gearshift in neutral, and the throttle at idle, see if the starter mechanism works freely.
OptsyEagle
Yes. Make sure you turn the throttle grip to as slow as much as possible and if the motor is in neutral and the starter still doesn't pull, it must be something with the starter, although I can't think of what.
AlTn
possibly the starter screw is loose and allowing the starter to get into a "cocked" position ...if it is the starter mechanism
ondarvr
I have seen the in-gear lockout mechanism for the pull start jam and not let you pull the rope. If you can turn it by hand it isn't seized, at least not at this point.
oldboat1
There is a spring activated pawl that engages the starter pulley (jams the gear) to prevent the starter from operating when the throttle is advanced too far and/or the shift lever is not in neutral (ondarvr's post, above). It's possible the spring is broken and the pawl is hanging the starter. The pawl is a plastic lever up at the pulley (red plastic, I think). When your son ran out of gas, I'm pretty sure he would have been in forward gear with the throttle advanced. He wouldn't have been able to pull it over at that point.
In addition, the pinion spring might be out of position and jamming the starter, or the main bolt too tight or vibrated out of vertical position (too loose) -- as indicated above. I think issues with the bolt will be unlikely, but never know. Don't fully unscrew the bolt unless you know how to safely remove the whole assembly. The starter spring can be dangerous.
FisheyeFool
Wow you guys are awesome! I really appreciate all the help you guys have offered! One thing I noticed when I pulled the cover off is a little arm dropped off that looks like a lever of some kind with 3 holes in it. I will investigate further tonight. Can I post pics on this forum if needed?
oldboat1
Pics really helpful on this end. Click on the attachment icon and follow the prompts. Having a parts blowup is also very helpful on your end (maybe Evinrude.com or similar).
FisheyeFool
Can anyone tell me what this arm or linkage goes to? It dropped out when I pulled my cover off my motor?
oldboat1
should supply a model number/yr if you haven't already (might have missed it).
That's part of the idle adjustment mechanism (plastic idle adjustment knob on the lower right side, looking from the front of the engine). Is anything else loose in there? Thinking something related to the pull starter function. Could try a pic. Another way to post pics is to click on the attachment icon on the right when writing a reply (find the pic on your computer, and follow the prompts to attach.)
edit. I think the screw that holds that piece holds down the fuel connector, but not sure. That screw or metal stop probably would not cause a problem by itself, but would want to look under there to be sure. Screw is probably in the pan somewhere.
OptsyEagle
You can see it installed on this 1975 9.9HP motor. This one has the starter removed but the part you have is screwed onto the right side just above where the fuel hose connects to the motor.
FisheyeFool
Yes I definitely see it. Thank you for the help. I found my slow speed adjustment knob in the bottom of my boat and it doesn't seem like it is secured by anything but interference fit. How do I set the the proper range of this adjustment before reinstalling the dial/knob?
Also is there an online manual anywhere that I can use as reference for this motor?
http://s1056.photobucket.com/user/aerohead77/media/15 johnson/image_1_1.jpg.html]
[/URL]
