nphilbro
Thread starter- Joined
- Dec 19, 2011
- 304
I'm hanging a 225hp Evinrude on my 19.9ft Glasply runabout next week. It's not really top end that I'm trying to achieve since I already get 41mph from my Johnson 140hp (at 5000-5200). My hole shot right now is extremely sluggish with a 13 1/4x19 SS and I can't keep a steady plane unless I run 25mph @ 4200rpms which kills the mpg big time and is too many rpm for long running times. The 13 1/2x 15 is a complete joke (ventilates, winds the engine). I've been looking for a 150 or 175 (6cylinders) but this 225 became available in my price range and my hope is that the power/weight ratio is maximized with this motor compared to the previous alternatives.
Does anyone have recommendations on the best setup for this? Right now it won't plane steady until at least 25mph @ 4200rpm. Should I be looking at a higher prop angle, 4 blades, combination of things? The AV plate will sit about 2" below the hull unless I put a transom riser plate on.
Objectives:
Maximize fuel economy.
Good cruising speed on plane w/lower rpms
The hull is rated for 200hp but the 225hp is the same weight - and as I said, more top end speed is not my objective but a strong, steady plane at cruising speed without winding out the rpms.
I've been thinking about reinforcing the transom anyway just because it's a 30 year old boat even though it's my understanding that the hard top/outboard versions of this same hull run 225hp motors all the time. I spoke with a mechanic at one of the Port Angeles marinas today and he thought a 140 was a bit light for this boat (he sees Glasplys all the time).
Any thoughts?
Thanks!
Objectives:
Any thoughts?
Thanks!
