Buzz Killington
- Apr 27, 2010
- 128
Per advice from you folks I ordered a needle valve kit for a carb on my 1400 that was puking gas.
Got this off the carb after removing the starter. I see two little spring loaded arms and a brass nut. Do the arms come off or do I just finagle the nut off somehow? Any advice for a dummy on how far to screw in the replacement?
Second question: now that the starter is off, is there any simple maintenance I should do to it? It works OK but is probably original.
Thank you!!!!
Thank you!!!!
