140 Looper loss in power
Bosunsmate
I got two old packs from wreckers for $140 583037 and 583041. Both now have spark to all cylinders. Battery is charging so everything looks in place.
If it also turns out to be base I’ll get a new one. Hopefully not.
When the packs are supersede by 582260 I assumed better software?
Sounds like your powerpack was bad now all are now firing.
Its probably a change of supplier of components internally
Riley C
Thanks for replying BOS.
Im yet to get one the water. But the dva and timing light are doing well.
So different superceeded pack or parts numbers don’t necessarily mean better?
Honorary Supreme Mariner
I do not believe there is " software " involved with a powerpack.
Faztbullet
Those are older packs and part numbers are superceded…..
Part Number......0583037
OMC® SYSTEMATCHEDtm Part#.....777645
Supersession.....->0581404->0582262
Description.....POWER PACK CD4
Part Number.....0583041
Supersession.....->0763797->0582262
Description...POWER PACK CD4
Riley C
Thanks guys, so superceded doesn’t necessarily mean better. Just who is currently internally supplying the parts perhaps?
All good just thought I’d ask.
Bosunsmate
Nope, sometimes they arent as good as old ones as everybody knows with the whims of manufacturing.
They all do exactly the same thing. Ive never had one do any different "tuning" like on a car computer chip to make a car go faster- thats not how these powerpacks function (these are rudimentary).
Those car ones are software based but these powerpacks are just capacitor ie hardware based.
Ive no idea about new outboard motors with their much more advanced EMM, they may be able to have a chip provide a functional improvement
Bosunsmate
Probably a multitude of supplies. AVX for the capacitors for example, PCB (printed circuit board) may be Jabil.
There are thousands of supplies of each these days so its a big guess.
Removing the epoxy to see who made what is a massive task so ive never found out who the suppliers on mine have being. The epoxy is one way of keeping the electronics dry and also making it a virtually impossible product to repair if you have electronic knowledge. I suspect when they go wrong its from capacitor burn out
Riley C
If its case is blue plastic its junk......
Thanks Boss,
one has blue base (junk?) and the has a clear green case. This one you can see the capacitors and diodes.
The blue base one is a light blue. PN #583037
