Jim Robbins
Thread starter- Joined
- Jun 15, 2005
- 85
I have just bought a 18' Starcraft Holiday with a 140 Mercruiser outdrive and 4 cyl. GM motor (181 C.I.)
the previous owner changed to a electronic fuel pump, new plugs, cap, rotor, oil, filter, fuel filter & lines, etc. impeller, lower end gear oil. The serial number on the motor is 3129102 and the serial number on the outdrive is 2073371 can you tell me the years? What manual do I need to buy? This is my first I/O, I have worked a little on outboard motors for years. What can I check out?
What do I ask the Marine Mach. to check/setup on the motor and outdrive? Any other advice?
