aussieflash
Thread starter- Joined
- Feb 5, 2011
- 1,004
Gday all its been a while.
Removing outboard for transom repair and need to disconnect wiring,fuel and oil lines and throttle / shift cables.Im guessing its best to disconnect all from motor side.
Any advice on doing this the right way? When removing throttle and shift cables do I need to re adjust idle when re connecting or just re attach in same spot.
Wiring all heads to one plug near switch box,does this plug just pull apart?
Any help appreciated.
