clint ourso
- Aug 13, 2007
- 4
water temp alarm light on -what color is the wire to the temp sensor and do these wire go into the power pack connections or under the same cover. reason: I had checked the power pack, stator, and trigger because I didn't have fire and did not have this problem until I put it back together. The fire problem was my kill switch. I have a water gauage on the motor and it shows water pressure-- plus this light is on before it can get hot. Is there a wiring digram that I can get for this motor.
thanks
clint
thanks
clint
