danny9696
Thread starter- Joined
- Jan 4, 2009
- 111
Hi all I have an 89 1901 Bayliner with a force 125 on it, It usually runs about 35-38 with just me and a full tank of fuel @ about 4500rpm, thats the best I can get out of her, a friend of mine has a 97 force 120 on a 19' astro that weighs more than my boat, it flat runs, we swapped everything onto my boat just to try it out (not recommended, lots of work control...) but man did my boat run, almost 50mph @ 5400 rpm, I am running a 15 pitch prop and I can?t get over 4500rpm, we ran a 19 on the 120 and wow I was impressed, my compression is good @ 120psi on all cylinders, his was a bit higher at 125 but it would seem that I should be getting a little better, also with my 125 force I can run wide open down the lake and use 1/2 tank of fuel, the 120 used less than half of what I used, I rebuilt my carbs and re jetted them but it sure leaves a cloud behind it when running wide open
Can anyone give me any advice, maybe I am using the wrong plus? they seem way wet when I replace them,
Any help would be great
Thanks
Danny
Thanks
Danny
