125 force bogging
mikebreslin
i have a 1986 force outbord. idles fine with a little bit of smoke on start up. as soon as i get in open water and give it some throttle it will go but then about 10 seconds later it will bogg or stall. i turn the key over and it starts right back up. i replaced the gas line, cleaned the carb and fuel filter. not sure what else to do. plugs all look the same. no carbon on them. any advice would be helpfull or even suggestions. thank you: mike
NYBo
Re: 125 force bogging
Sounds like it could be a fuel starvation problem. But you'll get more responses if you post over in the Force outboard section.
