120hp johnson v4 93 is it a good motor ?
javsam
Re: 120hp johnson v4 93 is it a good motor ?
yes, it is good motor.<br />javsam
_mako_20
well its new to me so i have not had it in the water .i started it with the ear on it .its loud.
G DANE
Be sure to mix oil in gas untill oil consumption from VRO is confirmed, if VRO is still connected.
wilde1j
I had a 140 and it was way loud also on the muffs. Just fine in the water and a great motor (same block as your 120). Sold it at ~ 800 hours and still going strong.
_mako_20
Originally posted by G DANE:<br />[QB] Be sure to mix oil ineen gas untill oil consumption from VRO is confirmeas bd, if VRO is <br /><br /><br />THE OIL LINE HAS BEEN PLUGED OFF WHERE IT GO IN THE CRABS THE OWNER WAS MIXING IT 0NE qt for every 12 Gallons
_mako_20
I found out alot more about this motor today it a 1994 the gear oil was gray and tick . i took off the prop to check for fishing line . there was none . Not sure if it had water if it did it was very little.
MCM
Mako, if it had water you wouldn't see the water once it mixed with the oil, it would look somewhat gray and thick though. ;)
jy118lfd
want a 83 v6 that runs good? for your v4 plus some cash. I wantto change from a v6 to a v4 for my aquasport 19-6 <br />e-mail me<br /><br />jy118lfd@aol.com or jonathan.yahr@navy.mil
