boater chris
Thread starter- Joined
- Mar 21, 2012
- 6
I have a 1979 mercruiser 120hp 4 cylinder gm inline engine, that will not start. engine cranks nicely but will not fire. I had the same thing happen last year during my first start of the season, we tried to troubleshoot it for two days but could not find anything wrong with the coil, distributer cap or plugs. finally after pumping a good amount of gas into carb by pushing throttle multiple times the engine mysteriously fired. It started fine the rest of the year for me in 2011. Now the same thing is happening again, this time i made sure to pump a good amount of gas in carb(I can see it squirting in) but it would not fire. I tried to sprayy some starting fluid in carb but no help. I even poured a little gas in carb but still did not even sputter. I pulled off plug from coil to distributer and can see it sparking good. i took off distributer cap and all points look good so did rotor as far as i can tell no corosion of any kind. I really am a novice only my 3rd year with a boat and im not a very good mechanic so put any response in dummy terms. THANKS.
