120 HP Force-Tight Steering
vietnamvet
how do I know if my steering needs to be replaced,or is it on the rod at the motor.My steering id very tight and hard to turn.Can anyone help?
RRitt
Re: 120 HP Force-Tight Steering
disconnect cable from engine and see which of two is stiff. with engine lowered you should be able to turn it easily. It should be like opening the door on a safe ... a lot of inertia due to weight but once it gets started it should almost glide.
