120 Force tilt bleeds down when motor up
Namron
120 Force tilt bleeds down when motor trimmed up, works fine but bleeds down. Thanks!
WhiteHorse
Re: 120 Force tilt bleeds down when motor up
Mercury Force or Force/Force? Year model, please.
Namron
Thank you Skye, 1984 Mercury Force 120hp.
BrianTindall
These things are a big problem here. If you take it apart, you will find a ton of junk inside. Mine looked like metal mud inside. Replaced one with the extra I had, two months later the other started. You can take it apart and try to flush it out(I used keorsene), that's if it will come off the engine. You can flush it while it's still mounted by using scrap fittings and some plastic hose and catch containers. You can also replace the o-rings inside as well.
