120 Force doesn't idle after it is warmed up.
BarePaws
I have a 1998 120 Hp Force that starts and runs normally but after it is warmed up, while sitting at idle for about 3 minutes, it will stall and then not want to restart and remain idling. It usually takes about 4 attempts before it will start and remain at idle, then will try to stall when you put it into gear unless you move the shift lever forward quickly to open the carbs up. That seems to help it clear itself, then it will run okay until the next time we stop and idle for an extended period. As long as we don't stop for more than a minute or so, it usually doesn't stall out. Kind of acts like the carbs could be loading up rich, but I'm not sure.
roscoe
Could be flooding crankcase with fuel from the back side of the fuel pump, inspect and install rebuild kit.
Could be flooding if the enricher valve is stuck open and is pouring fuel into the intake. Disconnect, plug hoses, and see if the problem has gone away.
