115hp Mercury Optimax Question
Pony
Recently purchased a new to me 2005 Lowe Fishing Machine 175s (17.5ft long w/ 92" beam). On it is mounted a 115hp Mercury Optimax of the same year. Current prop is 19 pitch. I assume I should be at 5600-5700 rpm WOT....
I was finally able to take it out on a larger lake today where I could open it up and test it out. With my dad and myself in the boat along with 3/4 tank of fuel (full is 27 gallons) I was able to get 5400rpm when trimmed out. If I stayed trimmed down I was more like 4100-4200. GPS speed was 36mph.
Is this running as efficiently as I can run it? Should I have to trim out to get max RPM? Should I try and get that extra couple hundred rpm? and finally is 36mph decent for that set up??
The prop on there is aluminum....what would I see with a SS??
Pony
Re: 115hp Mercury Optimax Question
Bump....here is a video of my motor for reference.
jestor68
Your rpm range is 5000-5750.
Running your numbers through various simulators indicates a good SS 17 pitch will raise your rpm up to about 5700 and reduce your slip(presently like 21%) to about 11%(hopefully); and thus actually gain in overall performance, including a 2-3 mph increase in top speed, depending on how low we can get the slip percentage. Example; 10% would equal 40 mph.
Something like a MIchigan Wheel Apollo would be a good choice.
The Mercury Vengeance (SS) equivalent is the 13.125 X 17.
In reference to your video; if that was a full throttle acceleration, not impressive.
The 17 pitch SS will fix all that. :)
Pony
I didn't really "put the hammer down"......at 21 seconds is where I trimmed back out and picked up the extra RPMs. I had suspected I might be over propped.....and sort of figured I should be 40+ in that boat even with that load.
Is the Aluminum prop flexing a bit with that HP?
This is a big change for me......going from an 88 25hp Johnson.
Pony
May seem like a noob question, but what would be the advantage of a 3 blade vs 4 blade SS prop?
