115etl77s pdf manual
Grub54891
Good morning all.
I'm looking for a PDF manual for this motor.
115etl77s
J4801365
I belive I found them on here before, but lost all my info when the I-pad went south.Since upgraded to surface pro 3 so I should be good for awhile😁
Looking to change out a piston and gaskets,ect. any help locating one would be great!
Grub54891
Nope, Turns out the owner found another exact motor that is in good shape. He swapped them out and now has spare parts!
Grub54891
It's not them in the pics. The one that goes down, in the pic goes to the center under/behind the carb area. kind of a bugger to get to. Som e have a spring loaded pin you push, others are a bolt you unscrew. Not sure on that setup, been awhile.....
