115 fast strike water pressure
RBR5
I have a 1998 115 johnson fast strike what should water pressure be at wide open cranking around 5500-5800 and what is the minimum psi u can run at that rpm range?
If that motor is a 60*V4, I would expect it to have 25+PSI near full throttle. Not sure what the minimum is..
RBR5
No Title
Yea that's the motor I have. I have around 25 at wide open I'm installing a jackplate and was wondering what the minnuim was is why I was asking.
Gee if you suck air, I don't think you will have any pressure. Plug the top hole of the water pickup grating and extend the bottom hole, as best as you can, and watch the pressure.
bob johnson
I ran a V4 60 degree 115 hp on my boat and I also ran a hydraulic jack plate...I never had an issue with water pressure.... even my old worn out impeller gave me 20 psi.... a new one might give 25-30 even...... make sure you seal the end of the hose very good.... if it leaks then water gets in the hose and could freeze....if you run in cold temps.... the water pressue is supposed to push the AIR in the hose..... you don't want water running all the way to your gauge!!!... how well your T stats are working has an eefect on what your reading will be...... make sur ethey are opening all the way up....( should drop the pressure a little compared to slightly opening)
likewise if you remove the tstats...you wont get more than 5 psi...but you are getting all the cooling you need!!!!!!!!!!!!!!!!!....so pressure is relative!!!
RBR5
What hose are you talking about??
3,000 has all the paper work to the motor starting in like 2005 perfect compression
RBR5
I should be fine as long as I keep water pressure over 20 psi at wot with the jackplate
bob johnson
water pressure hose....the guage at the dash shows water pressure..... hose runs from dash to motor!!!!!!!!!!!!!!
that motor makes more than 115 hp they say....its the High Performance 115!!!
RBR5
Okay. Yea I've heard that like to really know how much hp they have.
I've heard a fast strike isn't any difference then a regular johnson 115 either...
