Re: 115 Evinrude..cant get in reverse..help if u can thanks
If you're trying to shift with the engine NOT running, spin the propeller when trying to shift.
If the engine IS running, disconnect the shift cable at the engine, then try to shift with the engines shift linkage. If the shift is now okay, the problem is with the control box.
If the shift is still faulty...... has the lower unit been off lately? If so, perhaps the shift rod has been turned out of adjustment, OR..... a lower unit problem exists.
Did the engine ever shift properly for you, and if so, what has happened since that time?
