Skippy the skipper
Thread starter- Joined
- Oct 29, 2007
- 20
I am working on a 115, 1978 that will not reach 5000 RPM at WOT. I have done the link and sync, rebuilt the carbs, checked the fuel pump and inspected everything I can think of but it still will not reach 5000 RPM. Compression is at 125 on all six, good spark on all six with the sparky. Let me give you guys some history on this engine. I am the 3rd mechanic to work this jewel. 1st guy replaced some ignition parts (don't know why but he never even checked compression). 2nd guy found low compression on 1 cyl and did a rebuild. I get the boat it dies while put in gear and will not wind up. I also find the carbs had not been rebuilt and were leaking gas horribly when the bulb was depressed. Ok I'm thinking this engine is drawing too much fuel out at high RPM so I rebuild the carbs and do a link and sync. Runs smooth and does not die now. Hooked up my trusty tach to #1 and only get 3800 at WOT, recheck link and sync (21 at max advance at WOT with the timing light) still no go. I have not worked on these distributor mercs all that much, could I be missing somthing? In did the link and sync found here in the forum and it was much better than my manuals. But I still feel that it may be an electrical problem. BTW I noticed a small drop in RPM when I would try and trim the engine at WOT, instantanious when I would hit the switch (possible stator problem)? Any help would be greatly appreciated thanks in advance!!!!
