110 octane fuel
Re: 110 octane fuel
i guess maybe i posted in wrong place
In this forum you've got current outboard mechanics, retired outboard mechanics, and a bunch of talented people who do the majority of their own work. I can't think of a better place to ask most outboard related questions.
Re: 110 octane fuel
I know its the right place for fixing stuff i was just wanting to discuss theorys and opinons i maybe should have posted in non repair outboard quetions i bet there are qualified people on here i was just looking for someone that has tried or used higher octane in outboards to see how different they may run i know out of 5000 people a few have tried using it i wouldnt even try or think about it in a newer motor i consider the fuel higher quality than other fuels cause its filtered alot put in smaller tanks and less chance of water in gas
Re: 110 octane fuel
I've been following this thread with hopes that someone would explain why "high octane" fuel is advantageous in some engines and "waste of money" in others. There have been rants about cars and bikes running faster with high octane fuel but none of that has been backed up with proof other than "I seen it!". So lets set the record straight.
1) As mentioned about a dozen times, high octane fuel is used in engines THAT CAN USE IT. What that means is if the engine is a high compression design that would detonate with 87 octane, you MUST USE high octane.
2) Air cooled engines like airplane engines, run hot. Hot engines tend to detonate. Guess what -- high octane fuel is REQUIRED.
3) Since the advent of electronic fuel injection, vehicles have had knock sensors. A knock sensor detects detonation and when it does it retards the spark. So if the characteristics of the engine is such that the engine does NOT detonate on 87 octane, the knock sensor advances the timing to get optimum power for the current load of fuel. In that particular engine, adding higher octane fuel MAY allow a performance increase since the knock sensor and ECU may have a bit more advance to play with. Another car with the same type engine may have tolerances that doesn't allow that much advance. As for the "old Chevies" running better on high octane fuel, they had 9:1 or higher compression ratios and with no way to alter the timing when detonation occurred, premium fuel was required. If you manually advanced the timing beyond factory settings for "regular" fuel, certainly premium would help. However, compare those compression ratios to the 6.5 - 7.5:1 compression on outboards. Low compression and hard to light off high octane fuel do not go together.
4) You asked if there was timing advance on outboards. I would first suggest you actually buy a service manual for your engine so can learn about them and rationally discuss it. Yes, as you open the throttle, the timing advances accordingly. Now I'm sure you are going to jump on this and advance the timing so you can get more power. What you will do is screw this engine up worse than you already have it and likely hole a piston. Don't you think the factory had optimized the settings for reliability, performance and economy?
5) You said you can't make the engine idle but you certainly could if you disconnected the throttle cable, did the link&sync as outlined in the manual, and then readjusted and attached the throttle cable. Link&sync is a multi-page process in the service manual. If you do obtain said manual, you are advised to start at the beginning and go to the end following that procedure to the letter. You cannot start in the middle and have a decent running engine (except by dumb luck).
6) You cannot clean a carb by dumping any stuff down the throat. Carb issues are generally "internal".
7) While you may be on a budget, buy one less six pack and spend that money on proper gasket material.
8) Two strokes don't have valves so indexing spark plugs is generally not required or advantageous. It is used on some DFI/EFI engines to get the plug oriented for optimum firing of the fuel charge from the injectors.
9) If you are so certain your engine has an electrical problem why are you pursuing premium fuel as a cure for the problem. Don't you think some actual diagnosis would be helpful?
10) You admit to running old fuel. Even if it runs fine in another engine it may not be fine for this engine.
11) Stop comparing what happens with premium fuel in a car, motorcycle or airplane engine. They are all different, have different requirements and all are vastly different than your two stroke outboard that is 40 years old.
12) If you get better advice from another forum, let us know where that forum is. But remember, just because YOU believe it is a better forum does not make it so. Nor is it valid if you simply get the answer you want to hear. I would think at this point you would have come to the conclusion that you have a very poor understanding of this entire octane requirement issue and outboards in general.
13) The last bit of advice is to keep your issue to ONE thread.
Re: 110 octane fuel
Ok thanks for giving me the info the reason i asked about advance is i was going to try retard it a little and i dont drink acohol but i use to make alot of gaskets out of the boxes never used for carbs though but worked good for waterpumps and stuff i do have dumb luck with alot of stuff i had my engine adjusted just fine the high low idle and main throttle and i let run for awhile it revead up and down fine thought i was good till next day went to start it and runned like sh.t so had to adjust again and hold choke but now runs fine just not quit a little high throttle im tring to get boat on water by memorial day and was going to add a little of the 110 just tring to do to much at once i am cutting alot of corners by not rebuilding carb not putting primer on before painting i have to do transom today so im going to use wood i got in backyard 2 by 4s cause i cant wait to get on water so i hope it last a few years it doesnt have to be pretty but i dont want ugly as it was when i got it so anything will look better i only payed 200 for boat and motor spent alot on stripper i just sprayed trailor no sanding or nothing just sprayed black so im not really doing everything right way so any corners i can cut i will as long as it has a good look and runs good it was reallyugly when i got red primer on outside
JB
Re: 110 octane fuel
The more I read of this thread, the more like a troll it seems. The OP is not asking for advice, he seems to be asking for an argument.
If numerous experts agree there is no more to be said. Let us let this one die so I don't need to delete it.
Alwhite00
Master Chief Petty Officer
Re: 110 octane fuel
OP - How old are you? Just curious.
LK
Re: 110 octane fuel
Im asking for advise just not asking for dont do it it wont work how am i tring to argue when someone disrespects me first
Re: 110 octane fuel
Im 31 old enough to listen discussion boards are for argueing over different piont of views im i right so if someone says do it you just do it no whitch i do know theres more than one person saying that to me if you was getting heart sergery u just going to go with first doctor or check around untill last minute to make sure
scipper77
Re: 110 octane fuel
+1
The OP is clearly a seeing is believing kind of guy and I'm good with that. I say just put the 110 in and see what happens. The fact that we are continually rehashing this subject is where JB is dead on that this seems like a troll.
geoffwga1
Re: 110 octane fuel
You've had advice till it's coming out of your ears but you choose to think that your halfassed idea is the bizness in spite of the years of knowledge and experience accrued by the members who have answered your questions.If you are so sure you know it all why do you bother to ask.as for your age I would have thought 7 would have been closer.I am sorry if this seems offensive but you seem reluctant to accept anything told you without arguing about it so off you go and run your motor on 100 octane or tranny fluid or snake oil or even bull semen then come back and tell us how long it took to wreck your motor.
emilsr
Re: 110 octane fuel
Maybe this will shut down the thread. :rolleyes:
Re: 110 octane fuel
Thats a good one this phone sucks i dont have computer and once i write no goung back to fix or have to start over to bad there arent more guys like you on here that have humor instead of insults
emilsr
Re: 110 octane fuel
Glad you understood it was a joke.
What these guys are telling you is correct though. Race gas isn't appropriate for your 2-stroke outboard.
