100hp 4 stroke yamaha 2001 inspection
fisheymikey
hi,
I want to purchase a 100hp 4 stroke yamaha 2001.
before I buy I want at least to do a compression check does anyone have the specs?
also what else should I check for the guy seams a little sketchy or maybe is my paranoia therefore I would like to verify most common issues with this engine
thanks
mike
99yam40
Re: 100hp 4 stroke yamaha 2001 inspection
Have a Yamaha shop do a leak down test and go over the motor for you to make sure all looks good.
Or Run it on the water for a good bit to make sure it runs well at all RPM and loads
