05 Seadoo GTX SC
fishinfill1
Hi there,
I have a 2005 Seadoo GTX SC, and my problem is that i started up the ski yesterday with the flush kit on and it started and ran great. Then when i shut the engine off, i left the hose on for about 30 seconds on accident after the ski was shut off. Then when i went to start the ski today it cranked fine but wouldn't start then a lot of water starting flowing out of the back every time i attempted to start it. Next i took the plugs out and had seen that they were very wet so i think the engine might have flooded. What do i do?:confused:
Jeff Walkowiak
Re: 05 Seadoo GTX SC
change the oil immediately,, then crank the engine with the plugs removed and blow out the water from the culinders, then get the engine running, let it run on the hose and warm it up, then change the oil and the filter again.
GeoRXT
Yup. First thing take the plugs out and crank the engine with the accelerator pressed all the way down. Then change the oil and filter at least twice. If the oil is really "milky" change 3 times...and so on...
