05 175hp ETEC no power to ignition
backyardmk
When I flip the ignition toggle switch I get nothing. I checked all the fuses, and wire harness looks good. I'm getting power to starter solenoid but no power back to ignition switch. If I am missing something let me know!!!!!
multimech
Re: 05 175hp ETEC no power to ignition
The quickest way to check it is to put a key switch pigtail at the connector for the boat harness. If you have power at the key switch,then your boat harness is the problem. I have replaced quite a few boat harnesses.
boobie
Do the gauges work or is it the mtr just won't turn over ??
seahorse5
First lets find out what motor you really have.
There was no 175 E-TEC for 2005. What is the model number as you may have a FICHT based motor if its an '05, or if it's and E-TEC 175, then it will be newer.
A FICHT has 8 fuses and an E-TEC only has 1.
backyardmk
I'm sorry it's a FICHT. It has the eight 10 amp fuses. All the fuses are good. I changed the boat harness. I'm not getting power to guages or the trim/tilt.
boobie
Did you try jumping the solenoid to see if the mtr would turn over ? Are all the battey connections on both the battery and the mtr good clean and tight ?
backyardmk
Yes I tried jumping the solenoid, and the engine will crank. I am getting 12 volts to the engine, but it's not coming back to ignition. I'm thinking that the EMM might have gone bad or that I have a bad wire some where.
wilde1j
seahorse5, you are quite correct. '07 was the first year for the 175HP E-Tecs.
