Texasmark
Thread starter- Joined
- Dec 20, 2005
- 15,061
Ok you guys in the know.
I have a real tongue twister. What causes sneezing in recent technology loop charged triple with triple carbs engines that is temperature related? Occurs on muffs at idle and slightly higher rpms. The last time I had the boat out in Feb, '12 it was a stellar performance even after I had replaced a lot of the plastic interconnects on the carb/timing linkage in addition to replacing my fuel line and filter due to floating crud from it....over 10 years old, OEM gray.
Fuel? I live in N. Texas away from the coast and keep my boat in my shop with concrete floor and void of water/condensation pretty much. I always have SF in my fuel at the rate of 1 oz per gallon as specified or more. The last time I ran my boat was in Feb, '12. I buy fuel from a busy station, close to where I boat and buy the grade that has the most worn out selector button (87) which should attest to it's freshness. Station is Exxon. I use Pennzoil premium plus syn. blend oil at 50:1.
Went out yesterday, stellar day, wind <5 mph, temp in the 70's with about 5 gal of fuel/SF from Feb, and added 5 gallons of fresh with 1-2 oz per gallon of SF added plus oil pre mix. I keep my boat in tip top shape.
On the water, the startup was fine and all till out to the buoys for the hole shot which set the tune for the day. Performance sucked. Tried everything that I could on the water with no tools, instruments and all. The guy would not come up to WOT rpms regardless of what I did and made some really funny metallic noises. We were out for over an hour.
In short, after getting home and doing some TS with instruments and all today, I have this sneeze that occurs randomly after 4-5 minutes of operation on the muffs whereby the engine just about dies, big puff of smoke out of the exhaust and repeats.
I put the timing light on the HV leads to the plugs and had a hot spark on all cylinders....light would pickup well before I even got the sensor around the plug wire. All cylds seemed fine. Today at home on the muffs, I swapped CDI's and then with one disconnected (input signal wires) to see if I could stop the sneeze and no results. Basically went through each cylinder by swapping pairs (kept 2 running and would swap the 3rd one) and CDI's.
I ohmed out the yellow stator wires and the green/white and white/green wires from the stator and all were within spec. I didn't do the DVA test as the timing light results were so impressive.
At idle, tweaking the low speed set screws on the carbs did nothing.
Compression check was right at 118 and all cyls were so close I couldn't tell the difference. Used 3 gauges to check for accuracy.
Changed plugs from ones use on the water and same thing; surface gap OEM recommended.
When I goose it, on the muffs, rpms respond immediately to over 5k, rummm, rummm.
I am really stumped guys. Any ideas, and I apologize for the length of this but I wanted you to have some up front info to help us to go from here.
Sometimes you (one) just have (has) to suck it up. You can't help others all the time and this is my time for some help.
Thanks
Mark
Thanks
Mark
