01 Johnson 25hp mystery connector
Alumarine
Hi there. Just had a new head gasket installed in a friend's 2001 25hp.
I noticed that there is a connector hanging behind the CDI module that I don't think was just hanging there before.
Should this connector be attached more securely somewhere.
Also what is the connector for - I know it goes into the block.
thanks
Cofe
Re: 01 Johnson 25hp mystery connector
On mine, there are tin rubber covered clips over by the coils that hold that kill switch connector.
Alumarine
Great thanks. Does it get attached to the block or does it just hang there by the wires?
Cofe
That connector has a stainless steel wire clip to hold it together. The flat portion of that wire clip hangs on the tin clip that is by the coils.
Alumarine
Thanks all. I'll follow your leads.
I guess it only works if you have a buzzer or a remote with a buzzer.
This is just a tiller.
