‘67 evinrude vs 19?? Johnson
Old man Boat
What specific (or range) year/hp Johnson motor (if any) with a generator be compatible with a ‘67 33hp evinrude? Looking for a generator for the 33 evinrude and have come acoss a few Johnson motors that have them (last was a 40 hp on a 68 skiff). Wanting to put one on the restore project I have going on. Also, what treat (again, if any) will the hardware (brackets, etc) fit this 33 evinrude. Thank you for any info.
matt167
Ski Twin Vs Big Twin is a different motor. The generators may be the same, but brackets likely won't interchange
The 62 to 64 model 28 HP----1965 to 70 model 33 HP----1960 a to 76 model. 40 HP----Your location ?
F_R
The generator itself goes way back to the late 1950's without change. However the brackets had modifications up through the years. And don't forget, you will need a voltage regulator and a place to mount it, and wiring.
Old man Boat
I made a new wire harness from the motor to the junction box, but would like to add the generator. I have a manual that depicts the wire size and other items needed to install the generator. Just have to collect the parts.
Lots of good used generators / voltage regulators can be found.-----Join-----aomci----And post wanted ad there.
You just need to know how and where to look to find parts for these motors.-----Big dealers are interested in the " willing to spend "----$10,000 or more folks.-----Often not interested in the DIY crowd where they spend 30 minutes answering questions on a $5.00 sale.
