Fuel pump issues
curtdad
Hello all, new to the forum. Have a 1998 Seaswirl 250 with a 5.0 GL and a failed fuel pump this fall. Part number 2589B...I can't find anything comparable, do not know whether it is high or low pressure pump. Any help would be greatly appreciated, also where the devil does one purchase an owners manual with schematics???
alldodge
Welcome
Need your full model number or serial number, because a GL normally only has a low pressure pump and uses a Carb.
What problems do you have?
Motor will or will not start, running bad, have spark
curtdad
No start, no offer, pn 218 2589B. Can here the pump come on momentarily but no feed. I can start the boat on brake kleen, have load and ground at the pump..
alldodge
That number doesn't work for some reason
VP Lookup
Is your motor a GL- A, B, C, D etc?
The GL motors use a fuel pump relay and the relay is powered during cranking from the key and once running it gets power from the Alternator. Each feed has a diode inline and if it does power up while cranking then it can be the relay or the diode
The pic below is for a GL-C/D.
See item 23 which are the diodes. Use a voltmeter or test light to see if your getting power to relay while cranking
Can also remove the relay and use a jumper wire and jump the Red/Purple wire connection to the Yellow/Red wire
curtdad
Thank you for the response, it is a GL but I have no idea how to identify A B C etc. The fuel pump does come on for a short time, a faulty relay should not allow this...there is no heat on the relay. Attached photo
curtdad
This is all could find
alldodge
Being a VP/OMC I'll take it as a first Gen GL-so make it a A model
This is a low pressure pump and original part number appears to be replaced by 856955. Sierra 18-7326 and you might find others looking. Search for VP low pressure fuel pump
With it running for short time and still nothing being pumped, check your antisiphon valve on the tank, fuel line and filter to make sure it's not clogged
alldodge
This is a motor issue not a problem to the Seaswirl so moved thread to VP motor section to get more eyes on it.
