E-tec 40 hp
Crosbyman
ifyou see no lights on the EMM don't worry about EV diagnostic for now. find out why your EMM does not power up. Check all connections related to B+and grd from the battery to engine. Cable crimps . Easy stuff to track first.......... then focus on the EMM power source. see wire diagram in the manual did you download it ??
it MUST have B+ on purple from the front key ON.
I recently did load a defective PC with W10 + EV diag and I doubt BIOS settings are your problem.
saltchuckmatt
Here is two emm's. One is from a 2012 25hp tiller. The other is from a 2012 115. Both have the LEDs but in different areas. When you turn the key or pull start they all light up and go off unless you have a problem then it will stay on. The 115, the first light stayed on and it was an under volt. Turned out the flywheel magnets debonded. Re-bonded them and I'm good to go. There was a code...17 if I remember correctly.
JimDirt
So, after spending Tuesday Wednesday and Thursday evenings for an hour + on the phone having Guy try to walk me through this, he couldn’t even figure out what was going on. So I uninstalled everything and on Friday we set up remote access ( he lives near Reno) and he worked on it and worked on it, and yesterday he figured it out. I guess on the instructions there’s one step missing. So here’s the report. To my untrained eyes, I don’t see anything alarming
