Fiberglass Hull Restoration
Sandy-man
I have a 1988 Bayliner Capri with a 18' fiberglass hull. It's a beautiful boat but the gelcote has a fair amount of oxidation, or at least I think that's what it is. When I wash it, while it is still wet the colors are deep and vibrant, but as it starts to dry the colors turn chalky, like a white hazing. I've tried waxing and buffing but nothing I've tried so far works. See attached picture
Any suggestions, please? Thank you!
Start with 320, go up to 400, then 600. Then start with Aquabuff 1000, then go to Aquabuff 2000, then follow up with Finesse IT
redneck joe
hope you will have a buffer, not doing by hand.
I've used soft scrub before.
Sandy-man
Thank you, Scott. I will give this a try on a small spot and if the results are good I will work up a bunch of elbow grease to do the rest of the boat.
Sandy-man
Yes, I have a handheld buffer, it's a bit old and might not be as good as modern buffers though. I should probably buy a new one as the one I have was fairly old when I bought it at a garage sale many moons ago.
Sandy-man
Do you recommend a palm vibe sander, or by hand?
Wet sand by hand unless,you have lots of body work experience
There is only 0.020-0.030 worth of gel, you want to be easy on sanding. You only need to remove the layer that of oxidation
Get a harbor freight variable speed buffer/polisher
Drivewayboater2
Agree with Scott…wet sand for sure.
got my buffer from Harbor freight. I did ( and recommend this to anyone who buys one) repack the gears with “good quality“ grease. The cheap o grease that’s in there doesn’t do well.
good luck
Davetowz
Yep, wetsand, by hand. The Harbor freight buffers are pretty good these days. They have a good assortment of pads and actually sell good compounds. You tube has some good wetsand vids and buffing stuff.
Sandy-man
Alrighty then, I guess I'm sanding by hand as I have zero body work experience. I will check out the Harbor Freight buffer too. Thank you all. I appreciate your input.
Drivewayboater2
Watch vids…. There’s a ton out there. I only used 800 grit wet sand paper and got rid of the oxidation. Then buffed and then did a coat of wax. Good luck
Sandy-man
Thanks, Driveway, I will be working on this during the upcoming week after I'm completely done with fine tuning my recent motor rebuild and reinstall. I appreciate your input.
