Lou C
- Nov 10, 2002
- 13,844
Wow Ted that's amazing.
OK got a new business idea for you....
If you are ever on the Hull Truth, there are always a few threads on inboard or I/O conversion to outboards, and this stability issue is rarely mentioned, I bet you could do engineering consults to determine if the conversion will result in safe/stable seakeeping traits....provided that the owners, are looking for that information....
And looking at catalogs for modern sport boats, so many that now come with both I/O or O/B appear to use the same hull you wonder if the OEMs even went that far with it?
Saw this with Chapparal and Four Winns, several appear to use the same hull.
