Yes. I would hope for a noticeable change in the horsepower.
And increasing top speed with more HP would require a prop change.
(since the maximum RPM of the engine at WOT should stay the same).
So is there ever a need to also change the gear ratio of the outdrive.?
I would expect (and hope) not. Just a slightly higher pitch on the prop.?
I thought general consensus here is 10-15 hp for 1 mph of top end improvement, so calibrate your expectations as it takes a lot of $ to go faster in a boat.
Depending on where you are in terms of WOT rpm range you may need a prop change to go up in pitch. Most of the time its seems like people are over pitched somewhat (WOT RPMS on the low side) so try it out and see. Best advice I would give is to prop to the upper end of the rom range (4800) not that you have to run at 4800, but if the boat can nip the rev limiter the throttle response and performance will be nice through out the rpm range. The biggest thing I got from a 4bbl was much improved mid range punch and throttle response.
on the drive yes there are time you may need to change the ratio. My current boat is a 21 ft Sea Ray 200 sport. that I bought with a known cracked block (4.3/ 190hp/ 1.84 ratio drive). same boat was offered with 4.3 mpi (220 hp, 1.62 drive), 5.0 2bbl/1.62 drive, 5.0 MPI 1.62 drive.
I debated going back in with a 5.7 but thought( mistakenly) it would be too much power, so I put a 5.0 with 4 bbl carb and theroteically 260 hp. Boat only had 37 hours so I hated to swap the drive. Tried it out and was way under propped with the original ss 19". Went up to revolution 4 21" pitch and can just tap the revlimiter lightly loaded. So it seemed to me that the drive ratios help keep props within the normal 17"-21" range.
If I had done a 5.7 and a 23" pitch didnt work then defintely would have to swap the drive ratio or upper. Boat works great for the last 10 years but knowing what I know now I would have done the 5.7 and a 1.47 drive .
