What Can You Tell From This Picture.?
Mark R.
I'm considering picking up another project boat.
This one has a Mercruiser 5.7 Liter V8 engine.
But I don't know if it's a two barrel or a four barrel.
Is there any possible way to tell from this picture.?
I'm guessing probably not, but just thought I'd ask....
Mark R.
why not ask the people that are selling it?
They don't have any idea, and they don't seem willing to check it for me.
The boat is not near me, but I'm probably gonna go get it, regardless.
It's a non running project. I was just curious which carb it might come with.
I figure a 5.7 in a 19 footer should move pretty well even with a Mercarb 2bbl.
Isn't that also right about the time of the Pre-Vortec to Vortec transition.?
Lou C
Yep you can see the bolts for that engine lift bracket are angled, that says pre-Vortec to me. Vortec intake bolts go in straight down.
If the sellers are that unmotivated, I'd pass, the boat is 30 years old, there could be all kinds of things wrong with it, from engine/drive to structural. It could have been left out in the elements, not winterized, anything is possible. The last thing you want is a wood cored fiberglass boat with an I/O power train. Both need frequent and thorough maintenance to last.
Much better would be an aluminum boat with an outboard.
Having bought a 14 year old boat and having issues with the structure, some mechanical issues too, I'd never do that again. Save your money to buy something that doesn't need work, only maintenance. You underestimate how fast you lose interest in "projects".
Mark R.
I would walk away
Yeah. It's frustrating...
The person selling it seems totally honest, but just not knowledgeable...
Plus it's also gonna require a three hour road trip to go see it and get it.
If it was closer, I would already know about the condition of everything.
The engine is not running, and they're saying the block is not cracked.
I'm expecting to rebuild the engine and outdrive, which doesn't scare me.
But I am NOT interested in tackling a floor and/or transom reconstruction.
I can certainly walk away after I get there and thoroughly check it out.
It's a killer cheap deal but I will probably pass on it...
Mark R.
Ah, good clue. I will keep that one in mind as I continue to search. Thanks.!
All motors prior to vortec motors were V-belts
No, there were not any vortec motors with V-belts from the factory
The intake in the picture is NOT a vortec intake
Lou C
Yep the 4 bbl fuel line goes straight back to the left side of the carb (Weber 4bbl) just like the Edelbrock.
airshot
Forget the engine....a 30 yr old glasser for cheap means it will cost big time to rebuild the hull and structure. Owned boats for well over 60 years and and had a couple glassers. Never again, way to much maintenence to keep wood core in good shape. Engine and drive is chicken feed in comparison to glass work...Run as fast as you can away !
Scott06
that looks like a 2 l from the shape of the intake manifold runners and where the fuel line attaches to carb.
Ut forget the engine and check the stringers and floor given the age.
