240 2006 sea Ray Sundeck overheats at low RPMS
johnsimeone
I have a 240 SeaRay Sun deck from 2006. Recently the boat overheats at low RPMs usually at idle speed when let run for 10 minutes or more I have replaced the impeller and the raw water pump. I have inspected all the hoses for the thermostat and the power steering cooler. The boat ones is fine at 1000 RPM or more and only overheats when let idle for a period of time, anybody have any ideas?
alldodge
Welcome
Your issue isn't a Sea Ray problem it's a motor problem. What is in your boat and we'll move the thread to that area. If you have a serial number that would be most helpful
johnsimeone
Welcome
Thanks.its a Mercury Bravo III 5.0 engine. Serial number is OW384463
alldodge
Moved to the Merc section and thanks for serial number
Looks like your motor can have open or closed cooling and if open can have 3 or 7 point drain system, can you clarify?
alldodge
Ok THIS should be your motor
This is the open cooling system with 3 point drain
And this shows the check balls that are in the bottom of the exhaust manifolds
The check balls should remain closed when the motor is running, and open up when motor is off. They are used to drain water during winterization when the 3 point drains are opened. If check balls get stuck open they will let to much raw water go to the manifolds and out
Might also be your sucking air but finding out is harder than the 7 point drain. To find out if it's air, get a short piece or clear hose from the hardware store, a double barbed fitting and hose clamps. Disconnect the hose going into the water distribution housing on the front port side of the motor. Install piece of clear hose and run motor at idle and look for bubbles
alldodge
And what does seeing (or not seeing) bubbles indicate?
With boat in the water and not on a hose there should be no bubbles. Seeing bubbles means the impeller is cavitating or there is a hose or connection allowing air to be sucked in. You get air means less water, less water and things get hotter
alldodge
Understood. So to test this the boat needs to be in the water?
You said it over heats if it idles for a while, I'm assuming you in the water because you also said it doesn't if your above 1000 rpms.
We can only work with what you tell us
So does it over heat on a hose?
johnsimeone
Just found out from my mechanic that we already replaced the check ball assemblies
alldodge
Is this how the motor is run on the hose or do you use Muffs?
Are you in fresh or salt water?
When boat is in the water is this hosed capped off?
johnsimeone
It’s in salt water. While in the water, that is capped. Dry dock we have run fresh water through that attachment and also with muffs.
alldodge
Being in sale water, you most likely have build up which is restricting flow. Best way to find that is in water with clear tubing. Might even need to move the tubing around to find where the issue(s) are.
Being a 2006 with 373 hours in salt water my first thought is the exhaust manifolds might be an issue. In most cases manifolds need to be replaced about every 7 to 10 years, if they have never been replaced that's 20 years
