cyclops222
- Mar 21, 2024
- 3,218
If it is water ? It is sitting in the carburetor by now.
there is so much chit out there is rebuilt/new carbs and kits... hence why its worth doing it yourself. As said earlier in thread Cliff is the guy for quadrajets, Mikes is good too. Both sell quality kits but unfortunately no longer rebuild carbs.I rebuilt the carb with a Sierra carb kit. Not much improvement. Then, pressed for time, I bought a carb from an online carb shop that offered marine carbs too. I had a lot of trouble getting the "new" carb to run right. After hours of adjusting (on the water), phone calls to carb shop, it finally ran "pretty good". Son in law with family took the boat out (I was not there). Engine stalled and they had to be towed. I phoned Cliff. He had many comments about my decisions. I bought a carb rebuild kit from him. Cliff's gaskets were much thicker (one of my issues was thinner Sierra base gasket allowed carb to get too hot and vapor lock. Engine is running like new again. Got a refund on the on-line carb. Will always buy carb rebuild kits from Cliff.
Thanks for everybody's comments!
Ayuh,....... Most are just standard studs, available at better hardware stores,.... in various lengths,...Hi Lou
I did rebuild with a kit from Cliff's. Engine is running like new now. One thing I need to contact Cliff about (and want your input too)(It's difficult to catch Cliff to speak directly to him).
Cliff's very thick base gasket was unusable because it was so thick, that the front, carb-hold-down bolts were too short, so I had to use the original base gasket (pretty thick but thinner than Cliff's)
I am wondering if Cliff (or Mike's) offers slightly longer carb-hold-down bolts?
offers slightly longer carb-hold-down bolts?[/B]
