Someone else's outboard conversion fail
havoc_squad
Found this on Facebook recently of a starcraft islander/chieftain conversion for sale. 🤦‍♂️
This photo is is why some people shouldn't be allowed to get near good boats when they have zero qualifications and too prideful to ask the experts and listen to them involving overhauling design for outboard.
Even with a hydraulic lift that raises it vertical a few inches, that's not going to cut it.
jimmbo
Perhaps a Gil Bracket would have worked a bit better
JustJason
Looks like it may have been an I/O at one point? The transom has definitely been worked.
havoc_squad
To be fair, the motor is just a bit low. If it was up a few inches, and you never plan to tilt it up, run it!
How are you going to service the lower unit area of the outboard? Pull it off with a hoist every time you need to access it below like for an impeller change?
jimmbo
Gonna need a hell of a set of Ramps to get the motor high enough to remove the Lower Unit to replace the Water Pump Impeller
Mc Tool
Im with Chris in that if its what you have and you need to make it work with a limited budget ( doesnt look like a high budget outfit ) job done . While you guys are standing round poo pooing it hes off fishing .
yes servicing it might be a bit dificult but then a impeller can last 12 years :)LOL:) apparently and anyhow he could dig a hole and stand in that ( thats how my bro in law got the motor out of his bus )
99yam40
it would be interesting to see it on a trailer on level ground or going down the road
