Removing the side panels of angler 220 wa
k_petro
Hello
I got an angler 2006 220wa with an inboard mercruiser. I am currently trying to reach the fuel tank however if I remove the bolts on deck the panel is not moving. I have the same issue with the side panels in the cockpit port and starboard. Do you have any experience in moving these panels?
redneck joe
welcome to the forum.
Pictures always help - we may not know your specific boat put pics can help us walk thru what the possibilities are.
k_petro
Hi thanks for the reply
I am attaching the photo of the side panel
Thanks
redneck joe
so that panel, after you remove the screws is not coming out? If so my complete guess is it is spray foamed in place and acting like a glue
k_petro
I understand the same because it does not move. I tried also to move it at the fire after direction also up and down in case there was some kind of locking without success. In the photo you can see that not any silicone product exist. The reason I want to take it out is for inspecting the toilet pipe that is going aft. But until now no success and I am worried not to brake it.
flashback
did ya take the screws out? looks like they're still in. and yes, it was most likely installed with a sealant.
k_petro
It did not move actually seems like stuck. I was thinking if there are any hidden screws that I cannot see
flashback
Work around the flange with a thin putty knife and see if you can loosen it
k_petro
Is there a problem with the tank?
I want to clean the tank because I recently purchased this boat and there was diesel inside for more than 5 years, but I realised that this is also impossible to move due to polyurethane foam around the tank
