Starting engines with jump box & dead house batteries
deeman7777
Long story short, I overheard a well respected mechanic tell a group this info.
Story:
The boat had 2 dead batteries since it was in storage for a year. The boat owner was going to use a small jump box connected to one of the dead batteries to start the engine and let the engine sit at idle to charge the batteries. Shore power was not an option.
The mechanic said NOT to do this since the engine alternators would detect a low voltage of the dead batteries and send high amperage to recharge the batteries, which can be dangerous and possible fry some electronics in the process. The mechanic really pushed to have the boat connected to shore power (not convenient at the moment) and to let a battery charger slowly ramp-up the charging amps.
Thoughts on NOT using the engine(s) to charge dead batteries??
gman546
The warning is valid, but the explanation is a bit off. The alternator isnt going to send dangerous amperage through the electronics, but trying to charge two completely dead batteries can make it run at full output for a long time and overheat or damage it, especially at idle. I would charge and test the batteries first, then let the alternator top them off.
boscoe99
The mechanic does not understand basic electricity. Sounds like he is regurgitating something he read on the internet.
The world has been jump starting dead batteries and using the alternator to charge them since alternators (and older style generators) were discovered.
if the batteries sat for a long time in a discharged state, they may never take a charge.
best is to pull them and put a charger on them.
alternators at idle do not really put out much current. most require the engine to hit well above 1000 RPM to even start to put out power. if the boat is in the water, then I would get it started and run the motor up to about 1500-1800 RPM. if its on a hose, do not go much over idle.
MikeSchinlaub
In that Tige I did a little while ago, the panel to the batteries had a sticker that said to disconnect the batteries before charging or electrical damage could occur. So maybe there is some truth to what that mechanic was saying.
I'm not an electrician though, way out of my league.
Mc Tool
I dont think anything would be damaged but if the batteries are "push it under the door " flat then removing them and using a smart charger in recovery mode is probly the best option
boscoe99
Batteries are being charged and recharged every day by most every type of motorized vehicle. Strange sticker.
While at the same time an alternator is powering more and more electrical components in cars, trucks and boats.
dingbat
This warning has nothing to do with charging the battery, per se.
It’s all about preventing voltage transients (spikes) that could occur in the process that could easily damage sensitive control modules in the ignition system.
Keep in mind that most electronic ignition systems operate off 5 VDC or less and are very sensitive to polarity.
I’ve seen more than a couple of ECU blown by people jumping lawn mowers and tractors
jlh3rd
I've always been taught, read, (various sources over 51 years) and believe that a battery acts as a surge buffer to any transient voltage spikes. Since an electrical system is designed to operate within the alternator's charging range, no system should be damaged.
I've also understood over these years that an alternator is not designed to handle the work load of charging dead batteries over an extended time...but we do it anyway.
Lou C
ARCO has some good tech info on their site about alternators, one thing I recall from reading it is that alternators are more of a battery maintainer than a battery charger and as Scott said, they don't charge much at idle. In fact, even with a healthy battery, if it's even just at about 50% charge it will take hours to bring it up to full charge (like 4-6 or even more depending on the battery capacity). Every spring I put the charger on my batteries, if one or both doesn't come back up to full charge I replace it.
more on batteries:
boscoe99
Is the thinking that boats should not have lights, radios, gyros, pumps, trim tabs, MFD's, etc. installed as this equipment would need to be powered by the alternator of an outboard motor?
Lou C
No but it means that it has to be sized in terms of amp capacity for what loads will be put on it, or else the batteries will never be fully charged. Standard old school alternators for inboards are like only rated @ 55 Amps! Later models are rated for more but you need to take the whole electrical system into account.
jimmbo
Myself, I would use a newer Smart Charger, at about 8-10 amps, as these can sense when a Battery has sulfated from a long period of discharge, and will adjust the Charging Voltage to clear up the Plates. If this requires removal of the Battery(s) from the boat, so be it...
Mc Tool
I can recommend a Victron Blue IP22 smart charger....should have bought one years ago . My only beef is that the bluetooth range aint that great.
tpenfield
Late to the party, but adding my 3 cents . . . :ROFLMAO:
The Mechanic's advise has some merit, but the explanation is not 100%.
The Jumper battery will try to charge the dead battery and perhaps can bring the dead battery up enough to start the engine. (maybe) Once the engine is started, the alternator will then try to charge the connected batteries, which will most likely drag down its output voltage. In doing so, it may result in too much load on the alternator, causing it to fail. (thus the Mechanic's caution, I believe).
Lou C
I think it’s alway safer for your alternator to discuss nnect the battery and put it on a charger to see if it comes back up to at least 75%. If it won’t, buy a new battery!
Let's clear up misconceptions. Non-permanent magnet alternators are used in engines because they charge more at low RPM, when compared to generators. However, they require some back voltage to energize (excite) the rotor, to produce any electricity.
They produce AC voltage with the frequency proportional to the RPM of the alternator and number of coils.
As such, if you had a completely dead battery and you tried to manually start an engine by rotating it over, an alternator would not charge the battery, and if the engine runs on battery power, it will likely not start. When you jump an engine containing an automotive-style alternator, the jump power backfeeds the alternator rotor, allowing it to charge the battery. You could certainly put some voltage on the battery, which would feed the alternator rotor, and then manual rotation has a better chance of it starting.
Alternators can have some residual magnetism, which would induce some voltage that could be fed into the rotor, and produce charging. This magnetism can dissipate over time.
Generators generally have a permanent magnet in them and do not need any back voltage to generate. They charge less at low RPM but will usually charge a completely dead battery.
Before sensitive electronics were included in engines electrical systems, jumping an engine was no threat to those electronics. I expect modern engines to have some electrical protection for their sensitive electronics, especially in the marine environment, but would still be careful when jumping them.
Just a rant. Sorry.
redneck joe
i have similar, brought my 2018 deep cycle back to life. Took a few days...
it sat for prob three years, maybe four. Used it for a couple years on current boat until this year. I'm going to use it as power in my shed from a solar panel.
