80 HP Mercury trim
Kissdude
I was wondering where I can get the hydraulic parts for my trim motor. Was on the lake today and motor stayed down and would not trim up. I hear a click and that’s all but trims down fine. Any information would be appreciated thanks
Mc Tool
Might just be a relay . If your lucky you may be able to swap over the up relay for the down and see if the fault follows the relay . You could also use a volt meter to see if both relays are working.
There is only one trim motor that spins one way for up and tother way for down ...ergo , if the motor goes down it must be ok and the fault is most likely an up relay . The relays decide the polarity of the current flow supplied to the trim motor to give you up or down .🙂
Kissdude
Ergo is the name of my trim? Ya I'm wondering where to find these relays, I know they're older pumps.
Mc Tool
🙄no , ergo means " there for " ( its latin ) . I dont know where the relays are situated , but here are someScreenshot_2026-08-30-19-46-27-00_40deb401b9ffe8e1df2f1cc5ba480b12.jpg
Basically little square boxes that plug in , most probly near the electrical connection bits on the side of your motor cylinder block .🙂
Do you have the PTT with the trim pump and reservoir in the boat? If so, you can have one or two solenoids. The UP circuit will definitely have a solenoid, but the DOWN circuit may or may not have one.
I never had a solenoid go bad on that type of system, so first check the connections from the battery to the PTT pump solenoid. Then check to make sure the solenoid is getting +12VDC when the trim button is pushed. Do you still have the 3 button panel?
Kissdude
I believe it’s a 1979 80 HP Mercury 4832469 and the pump is inside boat. It was working on the lake but then stopped, had to lift from inside.. what a pain in the back lol. Think I have two solenoids and I control from the throttle up front. I hear a click for up and it goes down ok.
jimmbo
Might be a bad Solenoid, bad connection/Wire, as the Pump does run to lower the Motor
Kissdude
Any idea where to find a diagram and does the pimp have to come out to get solenoid out?
I believe those use a solenoid for UP and run direct through the switch for down.
redneck joe
Pretty sure not the hydraulics. Juat moved so not aure where its at but I'll tey to find my service manual.
