dingbat
- Nov 20, 2001
- 17,319
SAE J1527- A1 designed for use under decks and in enclosed areas. Its large diameter and stiffness makes it cumbersome for use with a primer bulb.Switched over to the A1 fuel line for ethanol fuels, same hose as my prior boat had in it for over 8 years and not one issue.
SAE J1527- B1 is specially designed for outboard use. It's smaller in diameter and much more flexible than A1. Works well for the flexiable run between the fuel filter/tank and motor.
