Omc 4.3l won’t stay running after 60 sec
Lou C
Something isn’t right here. If it’s a 1992 it came with a mechanical pump. If it has an electric pump then somone converted it. If that’s the case it’s probably an aftermarket set up. In either case you have to rig up a pressure gauge to find out what’s happening. If the pump is bad changing the relay won’t do anything. It’s a bit of a pain to get the correct fittings (I had to go to a hot rod shop no one else had any idea) but was able to rig up a good set up for checking pressure, volume & vacuum.
BR711
Thanks yes I’m having an issue getting the proper fittings I’ll keep checking some shops and rig something to test the fuel pressure- I’m thinking possibly the oil pressure switch could be killing the fuel signal going to test that this weekend
bruceb58
1992 was the year GM transitioned the 4.3L and other motors to a blocked off fuel pump port so they had to go electrical.
Lou C
The pic above shows a running test of a good fuel pump, 5.5 psi and it passed both vacuum and volume tests.
