Omc 4.3l won’t stay running after 60 sec
BR711
I have rebuilt carb professionally, replaced fuel pump, anti siphon value, fuel line, fuel separator and still same thing starts runs for about 45-60 sec and dies. Pumped throttle as its dieing revs up but dies again. Restarts with throttle right away but dies same as before can anyone please advise
Mc Tool
Fuel pump is replaced new
So you can be 90% sure its not the pump , but its not the only thing involved in getting fuel into the motor . If you can check fuel pressure at the carb inlet and verify there is enough pressure as the engine is dying you can eliminate a lot of stuff 🙂
BR711
Starter and linkage were replaced recently at the boat shop could it be something like the ESA switch they didn’t adjust properly? Unfortunately they sold out so I have no mechanic to try and call
pattyson
Sounds to me like its sucking air from somewhere. But with an electric FP, hmmm stuck needle valve. Blow some air though the fuel inlet on the carb. Listen for a pop as it builds pressure.
Post the compression numbers
Post the fuel pressure numbers
Check the oil pressure switch
bruceb58
If this is a mid to late 90's OMC(you need to specify)The fuel pump relay is activated while cranking by the starter circuit. Once it starts, the L1 terminal of the alternator energizes the relay. You can put a jumper in on the relay to get it to run, or use one of those relay devices for troubleshooting.
I have a set of these that I use to troubleshoot relays amazon.com/dp/B0CTTXMYS3?ref=fed_asin_title
BR711
Thank you ! Yes it’s a 1992 and this makes sense with the symptoms I’ll will replace them
Lou C
1992 4.3 might be the last year of the mechanical fuel pump…
Lou C
BR711
Replaced the relay and still same, runs for about 45-60 sec and then starves out and dies - any thoughts?
put a pressure gauge and verify you have fuel pressure. this is a troubleshooting technique that you keep ignoring.
read post #13.
use a DVM to check the diodes if your motor follows the circuit in post #13.
specifically check the feed from the key switch AND the feed from the alternator feeding the relays on both sides of the diodes. the Yellow/red wire should be hot when cranking, the green wire should be hot when the motor is running.
per post #13, make up jumpers to jump terminal 30 to 87. this is effectively hotwiring the fuel pump. then check voltages again. does voltage to the fuel pump change? does pump pressure change?
BR711
I replaced the relay and still same result? Any thoughts? Thanks
